Yes it does, that was the whole "HD" thing about it. 4.5 added firewire support from the DVCPRO-HD tape decks.FCP HD 4.5 does not support DVCProHD
http://psystar.com/index.php?&page=...product_id=38&option=com_virtuemart&Itemid=72What is this Clone you speak of?and where can I get one? $700 I could live with. as long as I can use FCP. Since that is the only NLE I have a clue about. Please let me know how to make that happen.
Right, which is why I advised him that he'd have to "capture" the footage over firewire. As long as you're not using 720pN mode, it'll work. Far more tedious than just updating the software to at least 5.0.4 or later and getting some P2 support...Barry:
I was referring to p2 card support in FCP HD 4.5. The OP was considering the 170 or the 200a.
Does anyone have experience with these mac clones? Is it a viable option?
David have you had first hand experience?
You can use any Class 6 card. You don't actually need to use Class 6 entirely, you just need Class 6 for the highest-quality modes (17mbps and 21/24mbps). You can use Class 4 for the medium-quality mode, 13mbps. And You can probably even use class 2 for the lowest-quality mode.Does anyone know if we have to use the higher priced Panasonic 32GB SDHC Hi Capacity Cards or can we use the inexpensive SDHC cards that are still class 6 cards?
They did - it's called the HMC150. :thumbsup:Would it be possible in theory for panasonic to make a 170 that records to sd cards?
If you already knew about the 150 and were referring to the 170's DVCPROHD codec, the answer would be no since the cards are not fast enough. But if cost is a main concern, the 150 is clearly the route to take.Would it be possible in theory for panasonic to make a 170 that records to sd cards?
As long as everything is up to class-6 spec, you should be able to get away with those super cheap cards (like at newegg/ebay) and watch the prices on the bigger ones drop over the next year.Does anyone know if we have to use the higher priced Panasonic 32GB SDHC Hi Capacity Cards or can we use the inexpensive SDHC cards that are still class 6 cards?
Personally I think it'd be a fantastic combination, but haven't had a chance to test that yet. I'll let you know as soon as I do.I've got the Letus Ultimate coming soon do you think the HMC150 will pair up nicely for narrative work as well?
Well, if you thought the 170 was going to be good for you, then the 150 sounds about perfect because it's the same basic camera, same imagers, and the main difference (recording media/codec) seems to be in your favor. You can record 12 hours on a single 32GB SD card.I was initially going for the HPX170 but thought event shooting is going to be more expensive with the P2 cards and I could probably only afford an additional 16g P2 card. And sometimes I record 4 to 6 hour long conferences!
David S. - Just using HDV and swapping tapes every hour practically. A Royal Pain which is why the HMC150 would be a dream in long event situations.4 to 6 hour conferences with what delivery medium?
Thank you Barry for your valuable input as always. I think I'm going to go for the HMC150 then. I got some LOMOS with my Ultimate that I'll be trying out with this camera so I'll also let you know how this cam holds up as well.Well, if you thought the 170 was going to be good for you, then the 150 sounds about perfect because it's the same basic camera, same imagers, and the main difference (recording media/codec) seems to be in your favor. You can record 12 hours on a single 32GB SD card.
Between the 200A and the 170, I'd recommend the 170 to everyone unless you have a specific need for that DV tape drive.
