Nope. Pixel shifting is a different thing entirely--it refers to shifting actual photosites on the sensors. . .
. . . Also, the HVX does not use the diagonal-pixel thing. That's Sony's HDV cams . . . It's not called pixel-shifting here, although any video produced by these cams is interpolated from the diagonal sensor data. Sony calls it "ClearVID", or something like that.
I'm sorry if I've missed the answer to this, but... have we had any confirmation on the issue of whether the camera is efficient in use of different frame rates... that is, does 720/24p use only 40% of the data space used by 720/60p; or better yet if it has a lower compression ratio for 24p than 60p?
I'm guessing your question is not how the image comes off the CCD, but do we still have the 21/24Mbps data rate at 720/24p (or 30p) OR does the data rate drop because there's less data? I wish I had the answer to this question.
Categorically not. The diagonal layout is used on the FX7/V1U, which has hideous low light performance.Might it be safe to assume then that this "read in any order" and/or the size/layout configuration of these CMOS is in part a reason for the excellent low light performance?
It is my understanding that yes, that is the way it works. The bitrate is fixed as 6 or 13 or 17 or 21 or 24mbps, so if you are shooting a slower frame rate, it just ends up that you have less compression per frame.I'm wondering if the AVCCAMs will be able to change the effective compression ratio so as to maximize image quality for the different frame rates (i.e., have twice as much effective data per frame when shooting 720p30 than when shooting 720p60).
Also, the FX7 and V1U had 1/4" sensors, as opposed to most other cams. If I'm not mistaken, the Z7U has 1/3" sensors and the diagonal pixel layout. Anyone know how sharp it is or how it performs in low light?Categorically not. The diagonal layout is used on the FX7/V1U, which has hideous low light performance.
AVC-Intra does it the way DVCPRO-HD does it (i.e., going to 1080/24pN in AVC-Intra does result in an 80mbps data rate). But AVC-HD, as I understand it, doesn't vary the bitrate based on the frame rate, so you could have 24mbps of 720/60p, or 24mbps of 720/24p -- with obviously 2.5x as much bandwidth applied to each frame.
. . . CMOS Rolling Shutter:
In order to see the rolling shutter effect on any CMOS Video Camera, try the following:
(1) Do a very fast pan. The objects that touch one edge must reach the other edge in 1 second or less. Using the highest speed shutter will help show the effect. It is possible to do this with a speed of 3 seconds, but the slant (or tilt) is small. Some have done a left - right - left - right pan back and forth to make this stand out. The worst I've even seen was when someone put a CMOS camera on the back of a motor scooter and videoed their driving. Great driving, but the rapid up/down movement of the camera made the world stretch and shrink.
(2) Take flash pictures. In most cases, only part of any frame is exposed to the flash.
CMOS technology has improved. Most of the fixed pattern noise is removed through digital processing, resulting is a less noisy image compared to the older analog solution. . . Bob Diaz
Bob, wonder if this was fixed with all the updates in the Z7U? On the Sony website there was a discussion about tweaks that had been added inside the Z7U to fix issues that were obvious in the Z1U . . PLUS . . there is a whole new video analog to digital processing technology in the Z7U according to the technical bulletin and description. I tried what you said and even shook it mildy and even held it horizontal and fanned it back and forth and then replayed the tape and nuttin'. Could this issue have been fixed in this A/D conversion processor update that was added with the Z7 generation?
I have not tried the flash/strobe tests yet but two people who have Z7's here in Pittsburgh said that they use them at weddings and have not had this problem stated with the CMOS in the Z1 which apparently has serious issues with flashes.
Just curious? I will try some flashes in a few days. Also, it doesn't show on the tape or on the card when played off the card. Is this issue only after importing? Or visible in the raw?
EDIT: Bob, here's the link describing this A/D dual noise cancelling "rolling shutter" issue by an independent source: http://digitalcontentproducer.com/hdhdv/depth/sony_hvr_series_0101/index1.html
"Who cares about the technical stuff as long as: A) the picture looks great; B) the media is easy to get into a machine, edit, and output; and, C) the material is easily archivable/reusable." Dr Dimento)
