HERE: http://www.dvxuser.com/V6/showthread.php?p=1358514#post1358514Check the press release section.
No reason to; Panasonic offers a free converter that will turn AVC-HD into DVCPRO-HD MXF files for editing with all NLEs.With regard to this whole transcoding issue why couldn't one just pick up cheap ole Pinnacle Studio 10 or 11, both of which read the AVCHD, the pump it out as any desirable format known to man (or woman) and then use that secondary file as the import to whatever NLE?
The 170 uses the same batteries, but it's unclear whether the 150 will or not. The 150 touts as one of its advantages that it uses an "intelligent" battery that communicates with the camera and tells the exact state of charge to the minute. I don't know if that's a superset to the battery or if that means that older batteries won't work at all.Do we know yet if it'll use the same batteries as the dvx???
Hands on with the HMC-150
I just worked on a shoot with a consultant and producer for Panasonic, using what is apparently the only prototype in the USA.
The camera wasn't even on my radar screen at NAB, but, selling at less than $4000, it looks to be a winner. I reviewed media shot on it, and it looked very much like HVX200 footage; the Cinegamma look so revered. The body is light and really comfortable for handholding, like the DVX100. 1/3 in chips, but using pixel interpolation, just like the HVX200, so, even though it can record 1080, it'll be softer than the EX1. At 720p, it rocks. One thing I noticed, the zoom function soft started and ended rather nicely on the prototype. There was an obvious mod, a clear plastic piece covering the top half of the audio level controls, already tiny and recessed deeply, which made adjustments a bear. A pencil w/eraser might be a handy tool for adjustments, unless production models are revised.
It already has most of the features of the HVX200, a few unique to it, like the advantage of post-recording: when you hit record, it adds a specified amount of frames already in a buffer, thus recording after the fact. SD cards are cheap media compared to P2 or SxS. It has the same body, chip set and lens of the HPX-170, a much more expensive P2 camera, but only 1 slot. HDMI, but no HD-SDI out, btw. Almost all features I noticed are covered in the PR. VF was brighter and cleaner than I remembered, although coarse in resolution. Using unshaded LCD panel in bright sun was impossible.
NLE's will support it natively, some do already, and the long GOP format can be transcoded, just like HDV, at the cost of time expended. My prediction: winner!
Especially for Indie filmmakers, documentarians, and event shooters, if it can be edited natively w/o transcoding delays. It'll be interesting to see how long a minute of AVC conversion to DVCPro takes using the Pana software.
iPaul
_________________
Paul Izbicki
i2inewMedia
Does anyone know if transcoding to DVCPRO HD creates a true 1280x720 image? When I looked in a few spots on the web it talked about 960x720.
kurt
Yes it has a non-square pixel aspect ratio. Most HD formats do; we really only got reasonably-affordable square-pixel recording formats last year. HDCAM, DVCPRO-HD, HDV, XDCAM-HD, most AVC-HD, etc., they all have non-square pixels.
DVCAM is a non-square-pixel format (as is DV and DVCPRO). 720x480, if you do the math, is neither 4:3 nor 16:9. It's actually 1.5:1, whereas 4:3 is 1.333:1 and 16:9 is 1.78:1.
