BobDiaz
The Professor
The lens is 72mm diameter and is the exact same lens (and CCDs) as the HPX-170. I expect the weight to be a tad less than the HPX-170, which is less than the HVX-200[a].
Here are the specifications from my WEB page:
Bob Diaz
> Supports 1080 at 60i, 50i, 30p, 25p, & 24p
> Supports 720 at 60p, 50p, 30p, 25p, & 24p
> Uses SD & SDHC Memory Cards and Records using AVCHD H.264
> Records around 3 hours at maximum data rate to a 32GB SDHC Card
> Doesn’t support over cranking and under cranking like the HVX-200
> Does NOT replace the HVX-200
> The higher model is the HPX-170, which uses P2 memory cards
The higher model looks almost the same as the HMC-150 and uses the
same CCDs and Lens.
> Maximum data rate, 21 Mbps average, with 24 Mbps maximum
> Uses 72mm filters
> 13x Zoom (3.9mm --> 51mm??) 35mm equivalent of 28mm --> 364mm??
?? = Not exactly sure, this is an estimate.
> 3 speed switch for the zoom
> Waveform Monitor & Vector scope
> Offers Pre-Record Function (never miss a good shot)
> Panasonic says it will be under $4,500 List.
Now is that $4,499.99 or $3,999.99?
As far as I’m able to see and test, the HMC-150 looks like it’s going to be an exciting camera for its price range. The images look clean, the colors are rich, and even in poor lighting with gain, the image noise is soft. The feel of the camera is wonderful, it is well balanced and not very heavy. Because it uses the same CCD and lens as the higher model, the HPX-170, the images should be about the same between the 2 models. The higher model will offer additional features and P2 recording. Back when Panasonic introduced the HVX-200, there were naysayers who felt it would be a flop, but Panasonic proved them wrong. Can Panasonic do it again at a lower price point? I sure hope so, but we’ll have to wait until October until we can know for sure. Stay tuned...
Bob Diaz
