Leaning towards the EX1
Cardbus, no longer seen in current equipment.
Nonsense.
http://www.dvxuser.com/V6/showthread.php?t=133168
Does it matter? P2 then requires an adaptor (quite expensive),
Nonsense.
http://addonics.com/products/host_controller/adexc34cb.asp
http://www.duel-systemsadapters.com/?productid=DP-0001
The advantage of SxS isn't just saved cost or neatness, the direct access means less bottlenecks in the PC and (if the other peripherals are up to it) the likelihood of far faster downloading than P2 via an adaptor.
Nonsense. I've downloaded both SxS and P2 cards on the same laptop, and they download at identical speeds.
Couple that with XDCAM recording about 3x as many minutes per GB as DVCProHD, and that means a recorded hour will download far, far faster with an SxS system.
Depends on what mode you shot in. An hour of 720/24p will download at almost exactly the same speed. An hour of 1080 will download faster with SxS.
All I can say is that it's quite a while since I personally saw Cardbus in a laptop on sale, but OK, "more rarely seen in modern laptops" may have been more accurate wording than "no longer seen". And how many of your list will still be on sale in 6 months time? In a years time? Fact remains that ExpressCard is current computer technology, Cardbus is obsolescent, whilst not obsolete.
Those aren't my words - see http://en.wikipedia.org/wiki/PC_Card or the PCMCIA associations own website - http://www.pcmcia.org/pccard.htm. Quote:
"The PC Card standard is closed to further development and PCMCIA strongly encourages future product designs to utilize the ExpressCard interface."
Is that not a pretty strong endorsement of ExpressCard (hence SxS) over Cardbus (and hence P2)?
Well - depends on your definition of "quite expensive" I suppose, and I'll admit that those are cheaper than what I've seen before. They still add a fair premium on to the cost of a laptop, and surely native acceptance of ExpressCard is preferable to an adaptor?
Not nonsense at all, and it's down to my original qualifier - "if the other peripherals are up to it". Quite often the harddrive, or it's connection to the laptop, will be the weakest link, and then SxS and P2 may well download at identical speeds. But use a fast RAID, and a connection method that can take advantage of it, and the weakest link may well then become the P2 card interface adaptor to the PC. Whilst the SxS card plugs directly to the fast bus and storms ahead.
Well yes, but with 1920x1080 full raster chips and full raster recording surely there is very little incentive to shoot 720p/24 rather than 1080p/24 with an EX? And surely with the HVX200 you would normally recommend 1080p/24 recording over 720p/24 anyway, unless you wanted slow motion? And not only will an hour of 1080 download much faster with SxS than P2, the same applies to 720p/60 as well.
My experience goes back to the P2 Store (there were no adaptors available back then) which was real slow compared to SxS direct. I only had two 4 gig cards and was shooting 720p60 exclusively hence the need for the P2 store.
We'll have to check back in six months or a year.
And the fact remains that you can use cheap adapters right now, today, and you can use your camera as a free adapter. So the scare tactic isn't valid.
Yep, that's straight out of the Sony marketing brochure. Somehow hasn't stopped Panasonic from taking 80% of the solid state market so far.
They're saying that any new development should be conducted on the ExpressCard standard, since the PC Card is now finished. As in, mature. Complete. No further work necessary. Doesn't sound like a bad thing to me.
However, how do you equate ExpressCard with SxS? That's a huge and inappropriate leap in logic. Yes, SxS uses ExpressCard. But I'll bet you dimes to doughnuts that when the ExpressCard situation becomes an actual hindrance, you'll see a P2 derivative that uses ExpressCard. Until then, it really isn't a problem. It's not like Sony has some proprietary stranglehold on ExpressCard technology!
Dude, please. How can $69 apply to ANYONE's definition of "quite expensive" when we're talking about memory cards that cost $900 and camcorders that cost $5,000 to $48,000? Give it up already. $69 to $119 is not, by any stretch of anyone's imagination, anything other than "dirt cheap."
Only if you choose to go that way, and what type of laptop? If you're getting a $2500 Macbook Pro, I'd say a $119 adapter adds a minimal premium, not a "fair premium." And if you're going with a Windows laptop, you can get out for under $600 and not even bother with an adapter. So, again, I reject the premise of your argument. It might work for "sky is falling" folks, but in the here and now, in the "can I work today" world, it's little more than FUD.
No, native acceptance of your preferred recording medium is preferable to an adapter. But again, it's a false argument. You can buy a laptop with both ExpressCard and PCMCIA slots right now. I just did. So you don't HAVE to choose at all.
That is true.
NONSENSE. How can it "storm ahead" when, by design, it's only potentially capable in the most theoretical laboratory conditions of barely being 20% faster? The bus does not define the card. The internal memory is the limiting factor, regardless of how fast the bus is.
The fact of the matter is that the CardBus interface is *faster* than the SxS design specification of 800mbps. Sony may have chosen a faster bus architecture, but they totally squander it. There is absolutely nothing about it being ExpressCard that makes it in any way, shape, form, or stretch of the imagination faster than if it had been in the CardBus form factor. This whole bus speed argument is a total red herring.
Yes, but you can't have all the blanket statements fall your way. Either the argument is valid or it isn't. If what someone needs can be satisfied by 720/24P, then the arguments about the EX's long-GOP edit-hell codec go right out the window, so -- just pointing out both sides.
Yes. And it will edit much faster and easier from the HVX than it would from the SxS. What's the point here again?
Barry you used the EX1 what do you think? Some people say the EX1 + LEX is unstoppable. I won't lie but the EX1 quality looks stunning. Still a big commitment for me to make because I love the HVX200.
The Sony marketing brochure!?! Hardly. The quote is from the top of the page of the link I posted immediately preceding it. Which is the PCMCIA official website, the page dealing with Cardbus. The overall body responsible for both Cardbus and ExpressCard. Impartial enough?
Well, most people I know interpret it as "design anything new with ExpressCard, not Cardbus". Look at the wikipedia link, the section marked "Technological obsolescence", quote:
"........ many devices do not need the speed of PCI Express, and often PC Card devices with adequate performance can be found cheaply, as discounted new parts or on the used components market, and will suffice for many users' purposes."
You can still buy (a very few) 4:3 TVs, and many more are still being used, that hardly means they're the way of the future.
Because an SxS card slots directly into an ExpressCard slot (no adaptor) and a P2 card slots directly into a Cardbus slot (no adaptor). How can that logic be faulted?
Not nonsense at all. Because the SxS card directly accesses the high speed system bus via PCIExpress. A P2 card accesses the adaptor, which then translates to access the internal bus, hence the adaptor becomes the slowest link, not the card itself. And the PCIExpress interface is rated at 2.5Gbs, and is serial, whilst Cardbus is parallel. See what wikipedia has to say about ExpressCard interfacing: http://en.wikipedia.org/wiki/ExpressCard
Comparison to CardBus
The major benefit of ExpressCard technology over the previous PCMCIA CardBus PC card is a dramatic increase in bandwidth, afforded by the fact that the ExpressCard has a direct connection to the system bus over a PCI Express x1 lane and USB 2.0, whereas CardBus utilizes an interface controller that only interfaces with PCI.
In the cases we are talking about, the bus DOES define the card. PCIExpress is faster than SxS, Cardbus is slower than P2. Given a fast enough peripheral to download to, Cardbus is inherently far slower than P2, SxS, or PCIExpress - it becomes the weakest link, and a Cardbus-ExpressCard adaptor only exacerbates that.
Let's be real here, current and future technology is on the side of SxS and not P2. That's just a simple plain fact of the latest cameras based on the latest format. Eventually SxS will succumb to a newer technology too. If Panasonic wasn't locked into P2 and created a new tapeless format right here, right now, there's no way in h-e-double-toothpicks they would base a new format on Cardbus. That would make no sense at all and It's quite clear the 'defensive nature' of Barry's posts in this regard. Which is okay. He's a Panasonic guy, not that there's anything wrong with that.
"the EX's long-GOP edit-hell codec"
Maybe I haven't done enough editing with this codec yet but it's much better then I expected, way better then editing HDV, at least using an Intel MBP & FCP.
Works pretty good on Vegas too. I've been shooting nothing but 1080/24p test since I got it. I am going to try a few different things this weekend I think.
Good of you to raise these points Barry!
Honestly the propoganda getting put out is ridiculous... mr harddrive and these petty scare type tactic claims is just laughable... but the real folks to blame are the annoying gits that start these threads - its never for the facts but just to make the monkeys beat their chests about their respective cams.
These disputes are coming straight of marketing literature (as Barry points out) and its important to rise above it.
So its obviously your fault Film It hehe!
And you should know better Buck! 'its a plain and simple fact' - oh really? What sillyness - its when we say these things that the opposite 'plain and simple' facts are read out and vice a versa... for pages after pages.
Of course its a tad hypocritical - i know ive put in my lot with these debates. I exist to give SteveT a reason to sound outraged on the forums ;) muhaha
Quite pleased with the way Premiere CS3 is handling it too. We're realizing tremendous throughput. It just moves the bottleneck to some other part of production now, such as DVD duplication. :)
I know where the quote comes from. I also know that it's plastered all over Sony's presentations as if it's somehow the "death knell" of P2. Funny how it hasn't quite worked out that way.
Because you're equating ExpressCard with SxS, and SxS is just one use of ExpressCard. That's all I was saying. Other systems use ExpressCard (such as the Lexar SSDs) and they're not compatible with SxS, nor are they anywhere near the speed. ExpressCard = ExpressCard. ExpressCard != SxS. SxS uses it, but you made a blanket equating of it.
Except that you're wrong. Cardbus is not "inherently far slower than P2". Cardbus is rated at 1.33 Gigabytes per second. Cardbus is about 40% *faster* than SxS. Sony could have put out a card with all of SxS's specifications and still based it on CardBus and CardBus would have been plenty fast enough for it.
No, it is not. Current and future technology is (as of today) a landslide for P2. SxS remains a curious oddity that so far hasn't caught on well at all.
Now, if you want to argue that an ExpressCard is a superior piece of technology to a CardBus, all other things being equal, then yes, you would have a point. But that's a different discussion. And it's no more relevant than "my camera has more pixels than yours, therefore it's better." It's the TOTAL SYSTEM that should be on the buyer's radar, not whether one has a 300x digital zoom and the other one offers "hypergamma".
So, why didn't they?
I have ZERO desire to get into this pissing contest, but the curious thing to me is why Sony chose to follow a different path. I know they have a habit of going their own way on incompatible media, so maybe that's the answer. I don't know.
Frankly, as soon as I can, I'll be bypassing the cards altogether with both a Firestore, and an Convergent.
I'm not trying to argue anything here, but my HP laptop dv9000 is about a year old and supports the express card, no cardbus. My previous Toshiba laptop from 3 years ago died but it had the cardbus. I'm surprised this HP laptop didn't come with cardbus, but it didn't, all I can say.
I honestly thought that meant cardbus was dead. But I hate it when they drop support, like they dropped parallel ports, serial ports, or cardbus. When they dropped the serial port from my toshiba laptop, it wouldn't work so well with one of those belken usb to serial adapters. To get a reliable working serial port, I purchased a Socket PC serial port adapter, which was a cardbus interface. Then when I got this HP Pavilion, cardbus had been replaced by express card...sigh...
I have the EX1, so the express card is convenient, but not required.
P2 will be around for a long time because of the reason Panasonic developed it in the first place. Newsrooms. Panasonic was out of the gate first with a tapeless workflow. News organizations invested in it heavily and now are locked in for a while.
P2 is perfect for news gathering because they do not need long record times and the turnover of a tapeless workflow with short amounts of footage makes life easier for the 24 hour news world. For everyone else its workaround time because the HVX was an afterthought. Does anyone remember the issues we all had at the beginning with P2? I bet you the newsrooms didn't.
SxS was much less painful than P2. I give props to Sony for covering all the bases when the cam was released. Panasonic had some of us mac users screaming and spending more money to make the P2 thing work with bits of software coming out very slowly from some crappy Panasonic Japanese website. Remember that $700 software that was being sold to just to view and safely ingest your P2 footage on a mac ?
Lets also remember the several companies that tried to make P2 cards cheaper with thier own cards and the P2 slot hard drives. What happened? They never came out. They stopped development. I wonder why.
P2 is pushed to the independent filmmaker but it was really designed for news gathering. They will keep it alive for years. The Ex and sxs is for everyone else.
I wasn't really paying much attention when the HVX was released, but I was looking at my Videography magazine from Summer 2005. They did a preview of the HVX, and talked a bit about the P2 cards.
I have a question for anyone who was involved in the early stages.
This article states that 8GB P2 cards were $2k+??? 2GB P2 cards were $900, and 4 GB for $1750. Why were they so expensive? And why are they still so expensive? For Sony to release it's new SxS cards at matching prices to current P2 cards in the same capacities, either they are taking some real losses or Panasonic is doing a fair amount of profit taking.
Not throwing stones, I'm just curious.
:huh:
I don't have the technical knowledge to argue any of the above points, but this seems a little rude. The guy was simply asking how much you would expect to pay for an Ex-1, regardless of whether he stated that he was a previous HVX owner. He never mentioned SxS vs P2, which is what the arguments about. He got his facts and I don't think hes posted since.
"Panasonic had some of us mac users screaming and spending more money to make the P2 thing work"
I remember that P2 Store was one glitchy sucker. Lucky I found out about how to reset the USB port to work with the Mac (probably from this site!) or I'd still be trying to get my footage off it.
For reasonably new technology SxS with FCP has been a real pleasure to use. Sony came out with that log and transfer plugin just in time to make it seamless for me.
