Mark Johnson
The Dude Abides
Hello?? Well I guess a 740x404 MPEG 2 is what it shall be. Now I'm fighting with 5.1 and compressor is still winning.
I'm not sure what your workflow is, Sean, but I'm a little concerned that the projected image will suffer because you aren't using the full resolution (720 x 480). Although your ratio appears to match the widescreen projection you you are going to have your 740 pixels horizontal squashed to 720 and your 404 vertical stretched up to 480. Is there some reason you aren't rendering out at full resolution (720 x 480)? See my post regarding setting up your frame to be 873 x 480 and then making it anamorphic at full res (720 x 480).
Maybe if you post what your work flow is and why you chose to use 740 x 404 we can understand better.
