Indywannabe
How do you guys get good (at least reasonable) resolution when compressing a 720p24 videw onto an SD DVD?
This is my first real attempt at putting a 2 hour and 11 minute video onto a DVD. I usually just shoot HD and deliver the edited final in .mov on a WD portable drive, so I'm not used to the horrible resolution once compressed to a DVD.
The HD version is absolutely beautiful. But when burned to a DVD it does not look as good as my partner's Sony consumer SD cam when burned to a DVD. In fact it looks absolutely awful and grainy. I would provide some samples, but the content is a new musical project and top secret.
HVX200
720/24pn
Cinelike V (all settings std)
FCS 2 suite: FCP 6, DVD Studio Pro 4, et al
DVCPRO HD - 720p24 sequence
The sum of the MXF files were about 45 GB. The exported QT file about the same.
The shoot was live musical theatre. It required no post video editing and just a little audio editing. I also used an HD monitor for proofing.
Used the "current settings" for Compressor. I also tried to go to QT first...with approximately the same results once on the DVD.
Compressor was set for 150 minutes 2-pass (took 9 hours) export from FCP. Much less time when exported to QT first. The end results are the same.
HVX200
720/24pn
