\Kholi, it was nice to hear your thoughts on the EX1 and the HVX200A. You are a professional that has used a lot of different cameras so I always value your opinions. The one thing that you did not include was a noise comparison. What are your thoughts on the levels of noise and low-light capabilities of the 200A with respect to the EX1?
The Noise level of the EX-1 is still slightly cleaner than the 200A, with emphasis on slight. I made sure to test both and for the 200A to be as clean as it is it's astonishing, the EX1 still has a slight edge in that department.
In all, I think it's DVCproHD's fault and not the camera itself. The EX-1 being Full Raster probably helps in this area.
The 200A is DEFINITELY cleaner than the 200 by miles, though. So to the point that +9dB of gain on the 200A is a totally acceptable image. This is similar to what I found with the EX-1, where pushing to about +6 or 9+ was still acceptable for practical usage. This makes both cameras theoretically faster, and is a great tool for 35mm Adapter users. In fact, both of these cameras are a 35mm Adapter users dream. Freeing up the light loss from an Adapter allows you to choose the ones that once lost "too much" light. So it's a good place to be at, either camera.
The 200A and EX-1 in 1080 mode are the same as far as lowlight goes. Neither was brighter nor darker in the same situation, same shutter, etc etc. I A/B'd footage from both cameras and saw no immediate/apparent difference in lowlight performance. In 720p the HVX200A was faster. For some reason (this is probably user Error) the EX-1 in 720p is pretty yuck. I couldn't see ever using 720p from the EX1, but then you have such a nice 1080p and HDV-1440 for longer recording times, why would you use 720p?
With the 200A 720p is a time saver, there's no HDV flavor so it's one or the other, with the EX-1 you can save time by using the non Full Raster recording mode which I find rather appealing.
Also, I hope noone assumes that I'm Panasonic ONLY. By no means. It's true, I love me some Panasonic but have plenty of valid reasons why. I'm making another attempt at putting together one of my own shorts here and I'm pretty much decided on using HVX200A + Letus Ultimate instead of the RED ONE based purely on cost and technological issues. With as much action and vfx as I want to do the RED ONE will probably add a bit of complication that I can't afford in the literal sense. Just as well, it takes more money to get one operating up to spec (rentals) than realized.
It would be the same deal if I had an EX-1, I just wouldn't want to risk tracking, panning and incompatible lighting anomalies on project that's thousands deep out of my own pocket. This only means that it's not the right tool for the job, and I've found that the HVX200A sometimes isn't the right tool for the job either. People want to use the RED for it's dynamic range and resolution, and that counts no matter WHAT your delivery format is.
Right tool for the right job peoples.
