__________________
"I'm releasing a new camera, its called the GREEN Purple. It will shoot 18k and record to GREEN RAY, 4:4:4, for under 5 bucks. Release date subject to change, all details subject to change, in fact, count on it."
Well I could if all cameras used the same LANC protocol. It seems that the hvx and the sony cameras use different lanc systems so it would be quite hard to work out. If these cameras were like the Red it would be much easier. on the red there is a lemo plug and you just short the two pins and it sets it to record. I could easily put a relay inside the receiver to do this. Unfortunatly the focus unit couldn't give a tally light to the focus puller, as that would mean having a transmitter in the receiver and a receiver in the transmitter, which would get quite expensive and complicated.
Maybe V2 can have a record button...
Green purple Camera?(LOL)
Where are the specs and images? Please provide links
Wow. Nice work. I'm pretty excited for it now.Afew updates:
the firmware for the processors (all six of them) has been written and im waiting to refine the code and get it all working.
Also I have had an ichat meeting with the laser cutting company and Im quite excited about the new motor mount. It will be layered delrin (a very ridged plastic) with an internal hidden spring to keep the gears meshing and to compensate for eccentric gear rings. We are going to try to keep it nice and smart, with nice curves and engraving.
The motor will mount on 15mm/60mm spacing but if anyone needs 100m spacing or 19mm rods then im sure we can work it out for you.
Its all coming along very nicely...
IIm not into the redrock Bait n' Wait philosophy.
