Okay, so I'm definitely outing myself as less knowledgeable than I thought but I appreciate the information I'm getting from you guys.
My question to Barry is, then what is the huge benefit of changeable lenses on the XLH1A if you still need an adaptor for proper DOF?
For Davide, are you saying that an A1 and Letus Extreme or Brevis 35 won't give me the results I want and that I'll need the Canon adaptor? Or are you only saying that I'll need their adaptor if I want to use Canon lenses. In which case, I think I'm happy with a Letus and Nikon lenses...
Thanks guys. And if you grow impatient, remember we all had to start somewhere...
Hi,
Actually I didn't mention the A1 in my post. I was talking about the XL series cameras (xl2, xhl1, etc.). My points were a) you can't put 35mm Canon lenses on the XL seriess cameras unless you have an EF adaptor and b) they won't have 35mm depth of field and c) they will have their field of view multiplied by about 7.8 so that a 50mm lens (which is a 'normal focal length on 35mm) will become almost 400mm on the canon xl + ef adapter.
You seemed to be of the belief that you could get 35mm DOF with the Canon XL camera since it allowed you to change lenses. I wanted to let you know that this wasn't the case so that you wouldn't buy one based off of that misconception. If you want to get 35mm DOF with the XLH1 you'll need to use a 35mm adapter like the brevis, letus, m2, etc.
You can definitely use the Brevis with the XHA1 camera and you can use it with whatever lenses you want. In fact, Dennis Wood, the manufacturer of the Brevis, uses an XHA1 for a lot of the internal testing of that adapter.
davide
