Flintstone
Hi,
The signal coming out of the VF connector is an SD signal and so the HD VFs will not do anything for you, you could spend more on the VF15 or VF20 and basically you would get maybe a smidge more resolution adn a nicer gamma curve. My suggestion would be, learn how to use the Histagram display, you will hit focus every time, and spend the money on say a BT-LH80W.
Hope this helps,
Jan
Really? SD signal?... Hmmm that's too bad... oh well. Then I'll adapt and use the histogram tool. Does the VF series provide better peeking? Or is it similar to the stock VF? And what would be the difference with the VF20W and VF20WB?
