Paintedsheep
UHD is still in development.
And the lab we use gives us a DVCPRO - NTSC master on a mini-dv tape;
But the video encoding algorithm is the same in Mini-DV and DVC-Pro...Same info.
Almost no difference in anything.
If it plays back on a standard def TV in the US it conforms to NTSC specs. If it plays back on an HDTV in the US it conforms to ATSC specs. It doesn't matter if it's an OTA signal, a cable signal, a satellite signal, a camcorder signal, a video game signal, a computer signal, or a DVD/BR signal. Try playing back a PAL tape in an NTSC deck and tell me how that goes.ATSC and NTSC refer to OTA (over the air) broadcasting...It has nothing to do with your DVD player or Satellite or Cable...
You can view programs finished in HD (or UHD when it comes out) on the appropriate tv regardless of ATSC or NTSC.
NTSC is 720x480/6, 60 fields a second interlaced. NTSC formats can vary in quality from low to high and can be analog or digital but they all still conform to the NTSC standard. There are varying quality of HD formats too (BR h.264 all the way up to Uncompressed 10bit 4:4:4 HD) but they all conform to one of the ATSC's HD standards. Of course newer and better formats will come out but they'll conform to ATSC standards or, in the case of something like Red, they'll be converted into an ATSC standard prior to distribution.And I don't know that ATSC won't support UHD...it's digital...just more info than HD.
Look at the myriad changes that took place in all broadcasting mediums that were supported by the NTSC system...hundreds of "improvements"...
Because equipment that's designed to work w/the HDTV standard isn't going to be compatible w/a UHD signal. People are still in the process of upgrading NTSC equipment that's worked for decades w/ATSC equipment so I don't think we'll all be willing to collectively spend billions again upgrading a few years from now.What makes you think that trend won't continue with ATSC?
HD is already on it's way out...you just don't know it yet.
UHD is on the way...no matter how much everyone spent on the upgrade to HD.
And when that happens I still won't upgrade.
Actually there is a necessity to change in the US since analog b'casting is getting shut down next year. It's not a coincidence that HDTV has been pushed and marketed like mad at the same time that the US government has mandated a change from analog to digital b'casting.They improve things to make more money...not because there was a necessity to change.
Actually that's not true...I can get a standard tv signal on my HDTV with a regular set of rabitt ears. ATSC is the new standard for OTA signal.If it plays back on a standard def TV in the US it conforms to NTSC specs. If it plays back on an HDTV in the US it conforms to ATSC specs.
Of course it will...it the same type of signal (digital) just with more info...aka...higher quality. We won't have to change the entire broadcast system...if we had to do that for every upgrade in quality we would have changed the system 300 times by now (technicolor, etc...)Because equipment that's designed to work w/the HDTV standard isn't going to be compatible w/a UHD signal.
That's the cart before the horse type of thing...Actually there is a necessity to change in the US since analog b'casting is getting shut down next year. It's not a coincidence that HDTV has been pushed and marketed like mad at the same time that the US government has mandated a change from analog to digital b'casting.
ATSC incorporates NTSC and PAL standards for backward compatibility purposes.Actually that's not true...I can get a standard tv signal on my HDTV with a regular set of rabitt ears. ATSC is the new standard for OTA signal.
NTSC has had some minor tweaks/updates but the fundamental aspects of the spec haven't changed. There's a difference between a "format" and a "standard". VHS, DigiBeta, MiniDV, etc., are all formats of varying quality that conform to the NTSC standard. You can't take a signal from a different standard (such as PAL) and have it play back on a NTSC device w/o first converting the signal from PAL into NTSC. The same thing applies to HD and UHD as they are different standards as opposed to just different formats that conform to the same standard. For example, you can't pipe a UHD 7680×4320 signal into an HD 1920x1080 monitor and expect it the HD monitor to properly display that signal w/o converting the signal from UHD into HD any more than you can pipe an HD signal into an NTSC monitor w/o a standards conversion.Of course it will...it the same type of signal (digital) just with more info...aka...higher quality. We won't have to change the entire broadcast system...if we had to do that for every upgrade in quality we would have changed the system 300 times by now (technicolor, etc...)
The experimental tech came first back in the 80's. The real world tech didn't become viable until just a few years ago. The mandate to change from analog to digital b'casting came before the real world tech was viable which is why the deadline got pushed back a few times (the original date was like 2002 or 2003 I think).That's the cart before the horse type of thing...
The government didn't just decide that there was possibly a better way therefore the changes were then mandated....
The technology came first. Then the decision to change over followed.
Yes, the switch just had to be to digital not necessarily HD.And nothing said that HD HAD to be implemented...it was a choice.
ATSC allows DIGITAL broadcasting...it says nothing about HD. The fact is that the digital information band is much more efficient and can carry what would normally be gigantic amounts of info.
How 'bout we check back in this thread in 2011 and see who owes who a beer. :beer:It can support UHD and many other future formats...
I guess we can disagree on the future (not the facts) but the proof , as they say, is in the pudding.
Give it a couple years...everyone who bought a HD camera will be scrambling to buy a UHD camera.
How is the brightening up the footage goin'?
-A
Am I reading this right...?
