Ryan E. Walters
I'm just going through my gear and trying to condense everything down to the bear minimum. I've been lucky enough to be working on projects that have budgets for the high end stuff. Everything is in working order, and has been used on various projects. I just want to lighten the load to the stuff I use every day, and then rent when I need the more specialty gear when I need it.
All payments must be made via paypal. PM me if you are interested.
Indi Skater- $120 shipped via FEDEx Ground. SOLD
Made out of wood, and has been used with the DVX, HVX & Letus Extreme, And even on a RED shoot. The wheels lock into place. They are a little stiff to urn into place, but once there they work well. This rig is designed after the P&S Technic skater. The plans used to build this were obtained from this thread: http://www.dvxuser.com/V6/showthread.php?t=40901 . You can see samples of what the rig can do at the thread.
Rowe Cine & Bogen Mini Dolly- $150 shipped via FEDEx Ground. SOLD
This dolly features 3 sets of 8 Rowe Cine wheels which have been attached to a Bogen 3127 Dolly. These wheels and bearings are the greatest- very smooth, and I have packed this dolly everywhere. I have taken it up into the mountians, and down through the hallways of sets. The camera can ride on a tripod for normal / high hight, or the tripod head can connect to the center for a low angle shot. All you need is PVC pipe, and you are set. The only draw back is that one of the locking arms has broken off. This does not prohibit the smooth operation or use of the dolly. You just need to be careful when you pick it up, as you can pinch your fingers if you are not payign attention.
Time Lapse Pan Control rig- $110 shipped via FEDEx Ground. SOLD
This unit can hold the DVX or HVX and provide smooth moves for time lapse pan moves. It can be computer controlled, and programed as needed. To see sample video you can check out this thread: http://www.dvxuser.com/V6/showthread.php?t=105477
