LoveFest 2008 Voting is now OPEN
Unlike Erik, I actually know my username. Yes, I tried it both ways actually, in case it wanted an underscore. But it should work with this:
Mark Harris
Yeah, I tried with both an underscore and without. No luck. Maybe it has to do with my username changing recently?
-Kegan
Hey, I had a long night! What can I do?
Oh, and better watch it Mark... I just found out I can still change my vote.
e
It should just be your dvxusername and your dvxuser password. Exactly what you would use to login on dvxuser is exactly what you would use to log into the voting page.
If you are certain that you are entering the correct information, probably better send Larry R a pm or report it here, so he can figure out why the system is not recognizing some folks.
later,
Jason
I didn't check the "remember me" button and I'm absolutely sure I'm entering the exact same information I would to normally login on DVXuser.
-Kegan
Ok, no one panic :), I'll ask Larry to have another look at the login system. If you can't vote, confirm that your username and password are correct by logging out and back in to dvxuser.com, and if you confirm you're using the correct user/pass, post a note here and we'll get it sorted out.
I just loged out of dvxuser to make sure my username and password were correct. It still doesnt let me login to vote though...
Mark, do you need somebody to lean on?
I guess I'm okay. I won't be ready to vote for a couple of days. And by that time all this should be straightened out. :thumbsup:
I have the same login problem. Double checked my login and password by logging out and back in here, but still no go.
