Ryan E. Walters
Footage update- you can see more letus extreme footage here:
http://www.dvxuser.com/V6/showthread.php?t=111625
I think it depends on your import tax of your country. They are not the same as V.A.T. It is extra. So you better check with your local customs office and the type of category it falls under.
I have to check what I paid for my M2. Custom keep it for some days.. And later asked quite a lot of money.
I'll check and I'll tell you
There is now the discount of $300, and they are throwing in a $50 lens support for free for those who buys within this 2weeks ,which makes it even sweeter . :-Laugh(DBG)-1
Thanks for posting Ryan.
I'm not used with HVX/XH-A1, but with my DVX+M2+Nikons edge to edge sharpness is absolutely there and usable, unlike that on your comparison. Is this simply because we're talking HD instead of SD?
Well, again I would prefer the lower res on the center of you're M2 grab, but all over the sensor (as I achieve), instead of a higher res only in the center.
(that's not for a "mine adapter is better then yours". I'm just looking for finer adapters and finer picture and my english is too poor to let me explain as I'd like)
Cheers
I'm currently shopping for a rod support system to go with the Letus Extreme and I'm a little bit lost. From what I understand, the Cavision "mini-dv rods support" are great and can be adjusted for a good fit BUT they're a bit on the short side (only 10"). Is that right?
Because of this, I'm also considering 45cm Cinevate rails system. Is it possible to match a Letus Extreme with those? From what I understand, because of it's design the Letus needs to be mounted higher then most adapter and also a bit offset on the horizontal plane.
Put simply, I'm looking for some recommendations on a good set of rods for a HVX-Letus extreme-mattebox-followfocus combo, around $300.00 - $400.00. Cavision? Cinevate? Anything else?
