How close are the serial numbers of the 3 cameras you have? It's possible to get a bad run of components that affect a large number of units, and hopefully not an engineering design flaw.
:thumbsup:
(using a thumbsup in a vain effort to not tear out what is left of my hair)
Ryan - Thanks for taking the time to do that. I know it's a pain.
I hate to say it, but checking out your grabs in FCP and looking at the scopes - it looks like you exposed much brighter than I did - and many of those grabs are hitting 100 IRE, so it's going to hide the cast much more (if there is one) due to the overexposure.
In fact, it looks like all of them hit 100 at some point in the frame.
I was going to post a 4 way comparission - with the 3 cams I tested and yours - but I don't want to give the wrong impression.
But I will say that looking at your grabs, my initial reaction is that you don't have much to worry about. The images seem pretty clean - though if you do any more testing I would suggest setting your zebras to 80, and exposing for that (just open up the lens until you see the zebras then stop down just a bit so that you'll be getting an exposure between 70-80 IRE.
Wow - thanks for going to that trouble Ryan.
I've got to say, after looking over your grabs in FCP, I can't see any issue with your camera at all. In fact, out of the 5 that I've seen grabs from under the same conditions - yours looks the best. Seriously.
Looking at the RGB Parade scopes, all channels seem to be in lock step with eachother, no major spikes or anything that I can see.
Now, when I crank the saturation WAY up, and crunch the levels in then I can sort of see a red/green tinge...but I would find it totally acceptable at that level. To put it in perspective - if I crank up the saturation on your clips, and push the levels to extremes to bring out the color cast, your grabs still look better than the raw frames from my camera.
:thumbsup:
Whatever you were seeing it in at some point doesn't seem to be showing up under these tests - or at least, I'm not seeing it.
Then again, maybe my perspective is skewed a bit now.
