Aron Peterson
Is there any reason to choose P2 over an FS-100?
Kasper Rye Petersen said:Hi Aron
I've worked with FS-100 a couple of times and there's some trade offs compared to P2 cards. The firewire connection between the FS-100 and HVX200 isn't very stable (to my experience) so I've gotten some drop outs. Further more if the FS-100s been shut off it takes quite some time for it to power on again. This is a problem when you are on a location where you have to run the camera and Firestore on batteries (so you have to power off when you can to save power) but you still want to be able to turn it on in a hurry, when needed. That's why I prefere the P2 cards. They are faster to work with and you don't get drop outs.
- Kasper Rye
There is EVERY reason to choose P2 over an FS-100. The FS-100 doesn't do many things that a P2 card can do. Primarily in clip playback -- P2 lets you sort clips by "good" or "no good" marker, pick which clip you want to play back by graphic thumbnail, play back clips while showing the slow motion or fast motion effect, and play back 720pN clips with audio. FireStore can't do any of those things. P2 lets you play back clips to an HD monitor so you can review your clips in HD. FireStore can't. P2 and FireStore can both record 24p in "pN" type modes, giving you 2.5x as much storage, but only P2 lets you use other frame rates and still get that benefit (i.e., if you put it in 12fps then P2 gives you 5x as much storage as normal, FireStore can't do pN mode on any frame rate other than 24 or 30).Aron Peterson said:Is there any reason to choose P2 over an FS-100?
Spend 10 minutes with both, and you'll understand very quickly.Aron Peterson said:I know. I really mean, for the money you save isn't it worth dealing with these FireStore issues until an updated FS or other HDD product comes out? Furthermore, why doesn't Panasonic just stick a bay there for removable 2.5" hard drives instead of trying to force filmmakers to buy expensive low capacity P2 cards?
32GB at the end of 2007 is exactly matching their release schedule. The only change to the schedule has been the slower rollout of the 16GB card; by their original "roadmap" we were supposed to have that a couple of months ago, so it showing up in May puts it 5 months behind schedule. But the 32GB at the end of 2007 is right on schedule.tmnt said:I, for one am very disappointed that a 32gb card is the highest capacity card Panny will release by the end of the year but is it very likely they're now being overly cautious with their release schedule?
Nothing official, but someone posted something here about SanDisk supposedly talking to them about licensing the tech and producing cards. Might be a rumor, or there might be something behind it.Has there been official talk of other manufacturers producing p2 cards?
Barry_Green said:Spend 10 minutes with both, and you'll understand very quickly.
VenezuelanD said:I know that laptops are moving away from the PCMCIA standard, but even though the new express card standard had been approved for a couple of years, its not till right a few months ago that they started appearing on laptops. So was panasonic supposed to just hold off until then?
VenezuelanD said:And I really don't see the big problem with using an older laptop to capture the footage, its not like a laptop capable of dumping P2 cards to a HD will be hard to find for the next 3 years.
R&D is why its expensive. Go make a P2 card.... See how difficult it is. Go make a fully functional Firestore.... See how difficult it is. Stop complaining please. Enjoy the miracle of technology you do have. a camera that costs 6000. That shoots 1080P. 720P. and had viariable framerates. gotta problem with that , go shoot S16 for a few shoots and see how quick you run back, praising P2 and how cheap it is.
There are many different shooting scenerios and some will be more suited to people than others. If you have a need for P2 technology, then do the math. If you are using it a lot it may be worth it to buy cards. If not, you can always rent them
[For those that want to sit around a ***** and moan about P2 and it's associated costs, then maybe you should think back about 18 months and you will realize that to acquire the images you now can with the HVX, it would have cost you about $100,000 just to get started
