John Froton
MrSleep said:is it possible to record variable frame rates this way???
No. Variable framerates are only available in 720pN (native) mode and that mode is not compatable with the NTSC signal output of the firewire port
siniarch said:hey John, I haven't tested it but I think DV-Rack has a way to record time lapse in which you tell it how many frames per second to record. hence doing variable rate. I'll have to re-examin this. I should be getting my bracket this week, so I'll be doing tests and I'll report back.
MrSleep said:thanks John! 720pn PAL yes??? im in Pal land.
USLatinContent said:
siniarch said:Dreamerinsf,
So here are some shots of my bracket. I still need to get a noga arm and put some plastic slides inside for a smooth fit, but it is all working great. My only limitations comes from DV Rack and the slight delay, but since most of my filming will be Film Style with Follow Focus (w/ marks) I think the delay will not be an issue. As you can see I've also implemented a space for an external Hard Drive. This way you can just swap drives pretty easily and its a very cheap storage expansion option.
Let me know what you think.
Thank you. I went to a shop to get the aluminum piece made. Its pretty much all welded or bend, so its pretty solid. But for custom work, things get very expensive quickly. I believe I paid around $550 for this piece. But if anyone has a Toshiba Protege M400 series Tablet PC, I'd sell it for $350.by: Dreamerinsf
I missed your message. Wonderful! setup.
I would like to know the cost to make this happen.
Awesome!
There actually is enough air space between the HDD and the Laptop. Its not completely sealed. And no, the HDD did not get Hot when I was using it.by: Mark Harris
I like it. I esp like the thing to hold the external HDD. But what provision do you have for venting and cooling that HDD? Does it get hot?
Also, how heavy is all of that, if you were to say, put that thing on a spider-brace?
