lonely leap
Hello. My burning question is simple...Is firewire 800 Fast enough to edit Hvx200 720p footage with? Thats it basically.
We have everything backed up on 8 250 gig LAcie drives which we use in the field but now wev want to edit from one location in FCP 5.1.2 wth 2.5 ghz Mac Pro Xeon. The cheap option is to go with firewire 800 drives maybe daisy chaining lots of 250 gig drives but i'm hearing whispers and that all they are..that firewire 800 is not fast enough to handle the data transfer rates needed to edit 720 of 1080 hd footage.
My questions are:
-Can i go with a series daisy chained 250 gig hard drives? if not why? it's cheaper, reliable as if corrupted it only takes down one of the drives as lonsg as all the raw footage is backed up and you can set multiple scratchd discs to work from in fcp...right?
-Or should i go with Sata Raids systems? if so which one? is it compatible with mac pro xeon, needing a pci slot to work off.
- Or thirdly is a fibre card system required? which one whave people been using and having most reliability with.
Lonelyleap
www.lonelyleap.com
Documentary film.
My questions are:
Lonelyleap
www.lonelyleap.com
Documentary film.
