Technical problems, 7 day film fest :(
j8chan
Hi there,
I'm currently editing a project for a 7 day film festival. First time working with hvx footage and I got a few problems and I am screwed if I don't fix them soon.
1) I can't seem to add effects in FCP to my footage. I have it highlighted and double clicked but when i got to effects -> vid transitions all of the options are greyed out. What am I doing wrong?
2) Maybe this is normal but whenever I put footage into the sequence timeline I have to render it to see it. If I can preview the clip why can't I see it in the sequence? Is there anyways I could make it so that it would show up there? I don't need full quality until I export or do color correction.
Any help would be much appreciated as I've been sleepless for the last 2 days and the deadline is fast approaching. Thanks in advance.
Did you make sure your sequence settings match your footage format (1080i, 720p etc). Maybe try doing an easy setup before you create the sequence.
J8Chan, which resolution did you used? I don't think HD files gives real time effects with a MAC book pro. maybe yes...
Paul
