mike the beginner said:We must be getting close now to having a complete list of lenses.
Well ask camera manufacturers if you don't believe me.macgregor said:If you move the CCDs block, you would eventually be able to focus. But you would change the framing too. You would notice it for sure. In fact, the more distance you make, the more macro the lense will become.
Just as large format studio cameras do.
I think you are wrong at some point.
mike the beginner said:I just wonder if this could be doable with Red for the opposite reasons (to get more deep DOF i,e increased DOF rather than shalow DOF
Unfortunately, there is no physics-defying magical mount that will increase the depth of field of a lens without effecting anything else.
Depth of field control is possible with a tilt-shift system, but this requires special lenses (usually fixed focal length) with a larger than normal image circle and these lenses are generally slow.
As there is no coupling of the aperture to the camera to stop down the lens at the time each frame is captured, frame rate is of no consequence to the lens and does not result in any unusual mechanical or optical wear and tear.adaml said:it seems to me that we'll be subjecting them to a type of use they're not designed for - 24 exposures a second (or more) for long periods of time.
