Emanuel
Cross-Examiner
If there is only 1080i from the HD-SDI offer @XL-H1, can we expect the same setup with the new camcorders or not? That is: 24f (25f@PAL) option available too? Or just 1080i?
If so, the HD-SDI will be limited to the interlaced mode and not also to the progressive one, right? And in this case even if we are handling @800_x_800 lines of resolution, the vertical one will drop 'cause the post-production via will be the only alternative in order to get progressive from the HD-SDI or am I wrong?
