im.thatoneguy
Since nobody really wants to edit in 4k, and something tells me avid isn't going to support 2k or 4k for the budget minded indie any time soon. What is the chance we might see some sort of EDL importer so that we can conform a final 4k edit from an avid EDL?
What is going to be the process for using proxies and 4k?
The dream system would be a piece of software that came with the RED camera. You could cue up all your nice pretty 2k images, tell it to generate an sd proxy for [check box] these clips. It would then embed the timecode from the original.
Edit in Avid or Final Cut or what have you. Export EDL. Load up that same RED Conform project. Then it would go through and generate a project folder which would consist of:
A folder for each cut.. kind of. I say kind of, because it would be nice if it just reduced each clip used to the used footage (including buffer for the EDL specified transitions.) Along with an SD (full color depth) proxy.
I say each clip reduced, in order, because of color grading. If you did a 2 camera shoot and you ended up cutting together the two cameras in a conventional ABABABAB sort of process. It would be nice if you just had to cc the A and then the B, and then the EDL would be smart enough to take the color corrected footage your grading software created and do the final master in whatever codec you wanted.
Using this sort of workflow, people could keep using all the exact same software and hardware they have now, with the exception of needing about 4 TBs in space. But that space could be normal 5400rpm hard drives since all of the work would be done offline, with four renders:
1) SD edit proxy
2) Full Edit EDL cuts
3) SD Edit EDL cuts
4) Final Render
Just in case you're still confused here is an example work flow.
You shoot three cameras in 2k.
1) Copy to HD from RED storage device.
2) Load it up in the Red Conformer and export your SD proxies to your Raid.
3) Edit and export an EDL
4) Load EDL into Red Conform.
5) Red Conform generates 3 files, summarizing the footage you used in the edit.
6) These 3 files are saved to your slow but large storage server.
7) Red Conform generates 3 SD versions and saves them to your highspeed RAID. (This is an optional step since at least combustion and I think shake can generate proxies inside of the application. Then autoload the proxies)
8) You do your grading using proxies in Combustion, or Shake or some program that can use 2k/SD proxies for grading. And save out a graded 2k copy.
9) Redirect Red Conform to your Graded footage and link it to the ungraded footage.
10) The project file should still have the EDL loaded, and it knew what still needed to be done to create the final master copy, so at this point you should be able to click "Render". Choose your final codec and settings and save out a 2k Final.
Now I presume all of this could be done using a suite of software, but it would nice to at least have the option of buying for a reasonable price, this automater. With this for the cost of about 4,000 dollars for 4 terrabytes of storage and a server to hold it, you could edit a mildly compressed (10MBs per frame) short, grade it and generate a master file using the computer you have right now.
Of course... this doesn't solve the problem of getting it off of the camera.
1) SD edit proxy
3) SD Edit EDL cuts
4) Final Render
