Zylight F8-200 LED Fresnel = 400w HMI
If you're wanting a 2k equivalent LED Fresnel there's also the Fiilex Q-1000 to consider. It has the advantage of wide ranged bi-color and hue adjustments. Zylight F8-200 has a wider range of beam angle.
The original Zylight F8 marketed itself as compact since it can shrink in size, but from what I recall of looking at it while at B&H it's actually a pretty sizable light, comparable in size to the Fiilex Q-500, just a different shape. The Q-1000 is apparently the same weight as the Q-500, except that it also has an additional 4.8 lb ballast. I wonder what the weight of the Zylight F8-200 will be.
Yeouch! Over 2-grand per light. That counts me out...
But WOW.
Between these and those Fiilex MONSTERS...LED lighting is REALLY getting sophisticated.
Incredible stuff here.
Hadn't heard of the new Filex, so thanks! Will need to check it out.
My Gaffer borrowed an early version of Zylight's F8-100 to test drive & but there was a flaw in the focusing mechanism that kept me from buying in. Thankfully the flaw's been remedied.
Both companies use high quality LED with great color, so size, weight, build, & output, will likely determine any decision. I was impressed by Zylight's robust construction, & less so by Filex's previous offerings. Whichever (if any) make the cut will largely be decided on how well I think they'd survive international travel.
Zylight F8 is also weather proof. This video below is pretty cool. Skip to 5:50 to see the Zylight completely frozen over but still working.
I saw a video which said they're aiming to price the F8-200 around $3000, which would be less than the Fiilex. The Fiilex is stated as being 1500-2000 watt Tungsten equivalent, which I gather would mean it's around 2000 watt equivalent at 4300k and 1500 watt equivalent at 3200k and 5600k.
The Zylight F8-100 has a 90 watt power draw, I believe the Zylight F8-200 is around 200 watts, the Fiilex Q500 has a 185 watt power draw, and the Fiilex Q1000 has a 340 watt power draw. This would lead me to believe that the Fiilex lights are brighter, particularly at 4300k. I guess if they're only using half of the power draw (170 watts) at 3200k and 5600k it'd be a bit less bright than the Zylight; I'm not sure if half the brightness and power draw is always how bi-color lights work at 3200k and 5600k?
Red Shark News said:
Zylight claims that the light output of the F8, the daylight version, is equivalent to a 1000W fresnel. A good rule of thumb is to consider that the average white LED will have an efficiency (strictly, a luminous efficacy) about four or five times that of tungsten in the range of wavelengths we care about. Quantum dots are a little better, but the purpose of the technology is really to control colour, not maximise output. As such, we would expect the kilowatt claim to be overstated by about a stop, which corresponds at least broadly to reality, although the device is still a lot more powerful than otherwise equivalent tungsten and the behaviour is not entirely comparable in either case. A hundred-watt light is more or less the largest that can reasonably be run from camera batteries, however, which is a useful option that becomes a little less practical on the upcoming 200-watt version.
Fiilex also sells an 8" Fresnel Lens accessory which gives you a beam angle of 10 degrees to 25 degrees. Not cheap and a bit of a pain to have to slap it on, but nice to know it's an option. They've also got a dome and other nice accessories which are an advantage over the Zylight.
I know the Zylight F8-100 you can slap a V-mount or Anton Bauer directly on the back of it; they're saying the F8-200 can be powered via Anton Bauer and V-mount as well, I'd guess also by slapping them directly on the back of the light, which is really cool. I think the Fiilex Q1000 can be battery powered, but I don't know how, and the ergonomics don't allow for directly applying two Anton Bauers to the light.
I feel like when I'm shooting with Tungsten lighting it means the windows are shut and I'm not battling daylight, so a lower powered light generally will suffice for tungsten interiors.
I'm very interested in the Practilite 602 as a lower powered bi-color LED Fresnel, and I know in their videos at NAB they mentioned they plan to make a higher powered version (I believe they said "four times the power") after the Practilite starts shipping, and the Practilite is supposed to start shipping in about a week or two is what they told me. So that could be another option coming for higher powered LED Fresnels.
One of the local video companies I work for just bought a Mole-Richardson 900W SeniorLED Daylite Fresnel after I recommended it to them. I got to play around with it at their studio last week. Pretty nice, though a bit heavy (41 lbs) and large for a lot of my work. It's equivalent to a 1200 watt HMI or 5000 watt tungsten without all the drawbacks of HMI and tungsten.
If I wanted that much power I'd be tempted to get two Zylight F8-200s instead though since two of them would be smaller and lighter, though sometimes it is nice to have one particularly powerful fixture. Set up two Zylight F8-200s outside (with no power outlets available) powered by four Anton Bauer batteries, and you've got a 4k battery powered fill or possibly key light for a day time interview if it's not too bright outside.
