Zuiko 50mm ???
pbarry
I own an Olympus OM-10 -35mm with a 50mmm 1.8 lens ( 1972
I need the Olympus OM Lenses to Micro 4/3 Cameras Adapter at 149.00$ for the AF-100
(http://www.cameraquest.com/adp_micro_43_fd.htm )
On eBay, there are several OM-10 ( with the 50mm lens ) to sale at $55.00$
Should I invest 149.00$ for an adapter ? I'm told it's one of the best 50mm lenses!
I'd appreciate your comments...:happy:
PB
Yes the cheap adaptors that you get on eBay do work, but you get what you pay for. They are all a little 'loose' fitting, which will allow lenses to slop around abit. Not always a problem, but with any manual lens, your hand is going to be on it as you focus and change aperture so it'll wobble the lens in that mounting a bit.
I ended up getting the pricey but good Olympus MF-2 mount.
David T
I concur that the inexpensive OM adapter works great. FYI, the Zuiko 50mm f1.8 that I own is very sharp. A little softer when wide open but not bad. It does have a different color cast than the Panasonic m4/3 lenses and the Nikon and Canon primes I own. The Zuiko 50mm is cooler, meaning a bit more blue.
