Zoom range etc
Joe
I saw this in another post:
F1.6 / f = 4.2-55mm (35mm equivalent : 32.5-423mm when in 16:9, 40-520mm when in 4:3)
Will this lense loose a stop when zoomed all the way in like the DVX100a does? What is the 35mm equvalent on the DVX100a zoom range?
Hi there. Not sure about your other question, but you will find that all cameras will lose a stop or so when fully zoomed in.
Regards
Yes it will be slower on the telephoto end, just like all cameras are (the XL2, for example, goes from 1.6 on the wide end to something like f/3.4 on the tele).
The DVX equivalent is 32.5-325mm.
The focal equivalent listed for the HVX is not correct, it's wider than 32.5. It should be more like 30mm-395mm. The focal-length equivalent they're referencing up there (32.5-423) was back before the lens zoom range changed; originally the HVX was supposed to be 4.5mm-58.5mm, and that would yield a 32.5-423 equivalence. Now the HVX is 4.2-55mm, and that yields 30-395 equivalence.
So on the telephoto end it will be only slightly more than the DVX100a? Also I do not believe my Sony DSR300 lense looses a stop when zoomed in all the way. If so it is certainly not noticeable. I was hoping that the new lense on the HVX200 would have enough zoom on the tele end to frame a similar shot as my DSR300 at full zoom. The DVX100a does not have quite enough tele for some of my shots.
It's got about 25% more telephoto than the DVX.
There are lenses that maintain a constant t-stop throughout the zoom range, and then there are lenses that don't. All these prosumer cameras lose f-stops over the course of the zoom. The HD100 does as well, even though it's not labeled as such.
