Chamber005
Carbonite Member
Without knowing what the Tascam can/cannot do, I can't really make an educated recommendation between those three options.
I would venture to say, despite my distaste for Behringer mixers, that your noise problems are likely worse in the DSR200. Without seeing/hearing your setup in person, though, that's just a guess. The mixer is still, likely, a part of the problem (albeit smaller). I'd say that you would probably see a marginal improvement with the Behringer + H4... and that would buy you some time to save up for a MixPre.
As has been said so many times around here, cheap audio is actually more expensive.
Okay, so I'll keep the H4 as the back-up depending on what the other guy comes back with regarding the DR100. Hopefully you'll be able to use your well-trained ear when he posts the samples as well (though I understand mic, etc has a lot to do with it too)
This is a great test. The wireless lavs sound awful, but the NTG-3 sounds really awesome (to my untrained ear).
http://www.vimeo.com/7568309
