Blackout
Greetings all,
We all know that sound for film and video can easily exceed the budget that you spent on your main piece of gear - your camera.
Any of the pro boom / mixer / recorder setups will run you past $5000 without even blinking. I had a sound devices mix pre, and a tascam hd-p2 which were stolen, so now I am left with my high end boom mic (a Sanken CS3e) with no mixer or recorder, and I am low on the funds, so I am getting desperate and wondering what it would sound like to run my Sanken CS3e mic into a Zoom h4n.. direct.. no mixer.
Since the Zoom h4n is so cheap, most people using it for sound are at an amateur level and using low grade to mid grade mics at best. Has anyone out there been in a fix and run a real high end condenser mic into the zoom h4n? I can't find any tests or samples on the internet...only recordings of the on board mics.
It has phantom power and manual level; control so this should work, but I am wondering about the quality of plugging a $1600.00 mic into a $300 recorder without even using a mixer. This could be a cheap solution until I can buy higher end gear again, but would people be able to tell the sound quality difference of the recorders and preamps, or is it the mic that is the key?
