4CH mode is usually unnecessary. It doesn't do the production much good to have a recording of stereo sound away from the action on the built-in mics in my bag.
It may be recording a blank track, but blank tracks don't eat up very much space on a memory card.
I believe this is not correct (although someone can chime in if I am wrong). Recording a blank audio track as a WAV will use the exact same amount of space as recording someone talking. It is still recording the same numbers of 1's and 0's, although since it is blank, it will be all 0's. This may not be the same if you are recording an MP3, but you shouldn't be doing that if you are recording professional audio anyway.
I suppose that to switch to mono I need to be in MTR mode?
That's right Mark. A blank audio file takes up the same space as one with sound. It's only space-saving if the tracks are recorded as discreet mono files. With the H4N you will get a stereo file with one channel having audio. Then you have to go edit that to take the mono side off the stereo file, and make a new mono file. It's not good to blend the 2 channels to do this either, as the "empty" side of the file can have noise. My H4 would record an odd digital sound on the unused track. I would take the file into an audio editor, select the used side of the file, then make a new mono track. Then take that mono track and place it in your timeline.
And the "settings" depend on the sensitivity of the mic, if you are talking about recording levels. People will try (and rightly so) to steer you to 24 bit recording because at that setting you can record at a much quieter level, and have much less risk of clipping. So the norm is 24 bit / 48k. Going higher will result in more battery drain, as it takes more processing to record at higher sample rates. 16 bit / 44.1 is, I believe what you get in 4 track mode. But you want 48k for video, not 44.1. Why not just buy a good sized card, and record at the proper setting of 24/48? Maybe invest in a preamp too when you get the money. That will help your sound too by getting the signal louder, which lets you turn down the H4N's recording level. That's where your hiss is at - when you use the recorder to pump up the level rather than a mixer.
Cheers
I use 4 channel mode all the time now (that I've been schooled on another forum) to track 4 isos out of my 552. I usually only use 4 tracks on a "normal" day. I have the 552 direct outs setup as mic-level pre-fade when using the H4n.
There's a mini-TRS (3.5mm) plug underneath the unit below the on-board mics which, when used, allows for input of two additional channels. CORRECTION: replaces the on-board mic channels with external inputs. Thus it becomes quite the decent 4-channel backup recorder. It's just in case the mix sent to camera needs some kind of fixing but I've found the recordings to be useable.
I had a custom cable made for the job; if you're a do-it-yourselfer (and using an SD mixer) you need to short pin 1 and 3 on both XLR inputs and tie them to the sleeve of the mini TRS jack. Then Tip-Left hot (Pin 2), Ring-Right hot (Pin 2). The cable I had ordered came with the cold terminals of the XLR inputs floated and I had to modify them to get rid of some awful ringing.
Now, however, it's been tested and works wonderfully. For anyone using a 552 (or a 442 or 302 I imagine) my H4n "gain" settings are 27 for the "mic" input and "41" on the XLR inputs when the signals from the mixer are mic-level. At this point -20dBFS lines up on both units and the 552 input limiters (if engaged) kick in just before the H4n clips. I can now just hook it up and go!
I don't use MTR mode on the H4n. That's the multi-track mode, made for overdubbing. Why mess with that when you don't have to?
I set mine at 48kHz 24bit, and use Stereo mode, even if I'm only plugging in one mono microphone. It's not stereo if there is only one channel. It may be recording a blank track, but blank tracks don't eat up very much space on a memory card. 4CH mode is usually unnecessary. It doesn't do the production much good to have a recording of stereo sound away from the action on the built-in mics in my bag.
Minor quibble - a stereo file is the same size whether you record on one track or two. A blank channel has the same number of bits recorded in it as a channel with sounds....
I set mine at 48kHz 24bit, and use Stereo mode, even if I'm only plugging in one mono microphone. It's not stereo if there is only one channel. It may be recording a blank track, but blank tracks don't eat up very much space on a memory card. ....
If you want to record actual stereo with an external mic you need either a stereo mic or 2 regular mics. When you say you have "back noise" what do you mean? Is it electrical noise, like hiss from noisy preamps etc or do you mean you have a lot of superfluous background sounds from the location - passing traffic, voices, etc - recorded in addition to the desired recording? What are you trying to record and how are you placing the recorder in relation to the subject?I just purchased a H4n and am having some difficulty figuring it all out. When I record in Stereo mode there is a lot of back noise and the audio is not nearly as clear as I had hoped for. Would buying a mic to plug into the H4n solve this problem? Or is it something in my settings?
I also have heard mixed reviews about buying a Sescom -25db cable. I saw your youtube video about how to use it, but I've heard a lot of people claim that they are not necessary for quality audio.
I am looking for the easiest way to get good quality dialogue recorded and am looking for any available advice!
