graywolf
I know, there has been a thread here that said it does not work. But, I finally got around to trying it. Seems to work fine.
First I set the main 1/2 output to +12db, which ought to be the equivalent of a +4 line level. Plugged that into the line in on the camcorder. Set the camcorder levels to mid scale. Set the F4 trim to mid scale. Fired everything up and talked into the microphone plugged into the F4. Levels went up and down in the camcorder as I changed the trim on the F4.
Audio out from the camcorder seems about the same as usual.
Apparently, Zoom intends the F4 to be used with a DSLR as the Sub Out can be set to mic level, but not the Main Out, Sigh! I guess I could crank the output down on the F4 and use the mic level input on the camcorder. I would need to experiment a bit to see how things work in more detail.
Next test will be trying with multiple inputs to the F4.
