zonghi adapter and wide angle problems
dilby
Hi all - I've recently been shooting some real estate interiors on my GH4 and have had trouble getting wide. As a temporary fix I was using my metabones speedbooster with a borrowed lens from a mate which is the Sigma 10-20 f4-5.6 EF.
As a more permanent solution of my own I opted to get the Zhongy non-powered adapter and combine it with a Rokinon/Samyang 14mm 2.8. I loved the flexibility of having a telephoto but they were just too expensive for me to get a faster aperture (low light has been an issue) so I opted for the 14mm 2.8. It means that I could ditch my speedbooster and save a bit of money (plus I'll almost always be on infinity focus anyway so I don't really need a smart adapter).
However now that I've received the new setup it doesn't seem that wide - in fact it's only marginally wider than my 12-35 panny lens. So I wanted to check that I'm doing all my lens maths right (which is really starting to mess with my brain!)
As far as I'm aware, the full frame equivalent of my 12-35 is 24-70.
And the 14mm samyang with the adapter should be 14mm still. So that should be way wider than my 12-35.
Another option I have is to go with a 10mm or 12mm samyang (they are all around the same price point) but the reason I went for 14 was in general being about there on the 10-20 sigma was the sweet spot.
One more wild card option would be the Laowa 7.5 f2 MFT lens. It's super small meaning it'd be great on a gimbal, and it doesn't require an adapter. I've seen sample video which looks good, but according to my previous
figures wouldn't this be wider than my 14mm? (7.5 x 2 = 15). The sample video just looks so much wider than what I'm getting with this setup.
Thoughts appreciated!!
You're Samyang 14 is actually a 28mm equivalent, with the adapter you multitply by .71 times 2, you should get around 20mmif you have the lens turbo ii , which is a little wider than 24mm. the laowa is much wider at 15,
Wow, ok. That explains everything, thanks a lot. So if I got the 10mm samyang it would be about 14mm (10 x .71 x 2 = 14.22). In school I wanted to do video because I hated maths!
still i would probably go with the laowa
I would too. It's fast at f/2.0, it's sharp wide open, and it's pretty affordable. The only downside I have seen is that it is a bit flare-prone, so you want to avoid shooting into the sun ( or bright lights ) if you can. ( still probably a lot better than using a Speedbooster with FF lens )
