So after ordering what I thought would be the ultimate set of lens gears, 60-116mm 6 ring set by cinematics. I made the unfortunate mistake of not measuring the exact circumference of all the focus rings on my small vintages... which most did not reach 60mm, including my minoltas, and most of my off-brand vintages. After that mistake, I decided to get a cheap zip tie lens gear on ebay for $7. This thing is awesome, and oddly enough is much more stable when pulling focus on a heavier lens with an adapter. http://www.ebay.com/itm/Flexible-Ad...?forcev4exp=true&forceRpt=true#ht_2025wt_1209
By design, I was thinking that the cinematics gear with its spokes applying equal pressure at every point around the focus ring and conforming tightly to the lens, would be the best solution. I'm surprised to say that the zip tie gear bound straight to the focus ring itself interfered much less and didn't "rock" the adapter every time I pulled focus. This really only applies to those who have adapters like the kipon, which don't "lock" in the lens perfectly in place like most other adapters. The kipon has a bit of give, when focusing inward / outward- becoming more noticeable with a follow focus.
Anyhow, if you have small lenses, or just a don't want to spend much on gears... these are perfect. Really wish I didn't spend $60 on the cinematics gears... but oh well. If anybody wants a brand new set 60-116mm hit me up!
