ectobuilder
Zeiss Batis 25 F2 vs Zeiss ZE Distagon 25 F2
For use with the Sony A7S. Which should I choose?
I think the Batis will handily beat the ZE in terms of optics, and it will also be smaller once you consider the adapter. The fact that it is electronic is a plus if you're going to do some photo work with AF, a con if you're only doing video (it probably will be fly-by-wire, which can suck big time for video work depending on the implementation).
For documentary I'm guessing it will be fine where the focus pull doesn't have to be exact and timed.
You can use the back button AF for a quick focus check and fine tune with the ring as needed, or you can use the back button to refocus while rolling. I do it all the time, purists say MF only, but in hectic situations having AF available is a huge help. The Batis distortion is well controlled and its sharp, it looks like a real winner. Fly-by-wire is the big bugaboo, ZE lenses are smooth - though some have a shorter focus throws than legacy lenses like the Contax C/Y's. Batis will be considerably lighter and you'll be able to use the awesome new tracking AF on the A7RII (and hopefully the A7sII soon).
