Rory_B
I'm a smooth and standard shooter, would I set it the same way as I setup smooth? Also, how does nostalgic hold up in bright sunlight? I'm gonna shoot some this afternoon but I was kinda trying to get an upper hand on what I might run in to...
It holds up perfectly fine in bright light. The image itself is brighter and less contrast across the range of the image, so at least in my experience it holds up fine. Even if the highlights have slightly less range(which I haven't noticed in my shooting environments yet) the shadow detail increases greatly.
Smooth is a good one as well, but I still see less contrast and a more even & "flat" picture in nostalgic.
I just turn the contrast down to -2. You can tweak the other settings as you see fit. Even Barry Green has said changing NR doesn't do much of anything, so I leave that and then saturation and sharpness are pretty much up to you. I leave the sharpness at 0, since I enjoy the look I've been getting simply lowering the contrast -2.
