SOLD Zacuto QR Shoulder Pad With Clamp
Status
Not open for further replies.
Erik Naso
Zacuto QR Shoulder Pad (1 of 1)-3.jpgZacuto QR Shoulder Pad (1 of 1)-2.jpgZacuto QR Shoulder Pad (1 of 1).jpg
Fantastic condition. Some very light scratches from storage but in perfect working condition.
Retails for $337.
Selling $260 FREE shipping with Paypal friends and family payment CONUS.
The QR Shoulder Pad is a completely universal curved, padded shoulder pad system. The shoulder pad is designed to sit directly under your camera or baseplate putting the camera on top of your shoulder as in a traditional ENG style set up. We call this our Recoil system and it can be adapted to most every type of camera. Having your camera directly on your shoulder eliminates the need for counterbalance which means your kit can be lighter and shorter.
The QR Shoulder Pad is a two part system that includes the shoulder pad itself and a separate (but included) DovetailPlate* that screws into the bottom of your camera or baseplate just like an ordinary tripod plate. The shoulder pad is set at an angle and made of form-fitting Akton Polymer, gel pad to settle comfortably into your shoulder. The dovetail plate comes with one (1) ¼ 20 and one (1) 3/8 16 screw in sliding tracks that allows you to position the plate at any point under your baseplate for comfort and balance. At the side of the shoulder pad is a quick release red cam lever. When tight, the lever is rock solid and will hold the pad in place. When the lever is pushed out and set at a right angle to the plate, you can slide the pad forwards and back on the dovetail plate to set the correct placement for your shoulder. When the cam lever is all the way extended, it releases from the dovetail completely. The dovetail plate can then act as a traditional tripod plate and snap directly into a tripod quick release plate on your tripod, monopod, slider or other standard piece of equipment.
Want to attach the QR Shoulder pad to 15mm rods behind your camera? Add our QR Shoulder Pad Rod Clamp.
*The dovetail plate included with this shoulder pad is compatible with Kessler or Really Right Stuff quick release plates. If you have any other tripod, consider adding the Zacuto Tripod Adapter Plate to make moving from handheld to tripod to dolly to slider a breeze.
Status
