ethansigmanproductions
Zacuto Follow Focus ZFF-1 $800 obo
Zacuto Beefy Grips $750 obo
Excellent condition. Hardly Used. Like New. Available for inspection and oickup in nyc.
Zacuto's Z-focus is an extremely accurate follow focus that allows the operator or assistant to pull focus. The Z-focus comes in single sided configuration.The mechanism utilizes aset of gears that connect to and spin the focus ring or Zacuto zip gear on the camera lens. The white disk allows the focus puller to create distance marked for repeatable focus pulls. The FF-adapter accessory converts Z-Focus to 19mm/15mm studio rods-lightweightdesign
The Z-focus comes sta dard with a .8 pitch, If you need more than one pitch those can be ordered separately
Zacuto Z-FF-1 Features
Completely gear-driven design for slip free, accurate movement
Z-focus includes a new operator's marking disc that allows the camera operator to see focus marks while operating the camera
Helicel gear adjustment screw to allow user to tighten up gear play
Interchangeable drive gears
Magnetic dry erase marking disk
Standard accessory port for Zacuto, Chrosziel, and Arri follow focus whips and speed cranks
Industry-standard 15mm lightweight rod mount
Lightweight design
The Zacuto Z-LSHK-B Zgrips Beefy are a pair of handgrips for HD camera packages between 22-40 lbs. i.e. RED cameras. These grips are infinitely adjustable with un-parallel strength. Each handgrip can move up and down, left and right, as well as fully articulate at the wrist. The handgrips can also move together pushing away from your body or towards your body. Each grip can move independently so you can have one grip further away from your body than the other grip. They can also be set at different lengths or positions. Like all Zacuto products, the Zgrips Beefy can quick-release with the flip of a lever. The Zgrips Beefy can be broken down as well and the handgrips can be used individually on any 19mm rod or 15mm rod. This is the most beefy, most universal handgrip system available.
See my other sales:
HVX200a
http://www.dvxuser.com/V6/showthread...2x8GB-P2-Cards
Schneider Lenses for HVX
http://www.dvxuser.com/V6/showthread...ter-for-HVX200
Duclos 11-16 PL Mount Lens
http://www.dvxuser.com/V6/showthread.php?343045-Duclos-11-16-PL-Mount-Lens-Mint-Condition&p=1986601898&highlight=#post1986601898
Lightweight design
See my other sales:
HVX200a
