Z1 First Impressions
DVDude
First Thoughts on the HVR-Z1U
Have had the very fortunate opportunity to play with one of the first official shipping Z1s into Canada, and here are my preliminary thoughts/notes after spending 2 hours with the camera:
- This is very much like the PD150/VX2000 scenario - these are the same camera, with just a few features making them different, such as PAL support, built-in XLR, etc. You will get the same picture quality from both.
- Just like the DVX100, the Z1 does NOT come with the shotgun mic that is in every picture of the camera
- Cineframe 24 is the exact same as the Cineframe 24 on the FX1 that I can determine. I had the FX1 and Z1 side-by-side.
- Cineframe 25 loses all the stuttering ugliness that CF24 has, and is smoother. However, it doesn't look particularly "film like", but that may change with filters/software and spending more than 10 minutes playing with that feature.
- CinemaTone Type 2 is more contrasty and has deeper blacks than Type 1. A bit too much deeper black personally (I was shooting Manfrotto tripods and Pelican black cases amongst other things under fluorescent lights, and they just went black with very little detail).
- Enhanced Focus does not work while recording, just like the FX1.
- You turn on Phantom Power for the XLR through the menus, not a switch on the outside of the camera
- The 4:3 and TV Safe markers are nice
- It is really cool to switch between PAL and NTSC. The camera has to do a re-boot, which takes about 30 seconds
- HyperGain (+36dB) works, but adds a lot of noise. Believe it or not, the Night Shot features on the $500 cameras work better - they can at least shoot in total darkness, whereas HyperGain needs some light
- All Scan feature (everyone else would call it UnderScan) is a nice touch
I liked the FX1, and like the Z1 too. It's up to you to decide whether the built-in XLR, PAL support and a few other features is worth the extra money. If not, get a BeachTek and put the money towards a HiDef monitor. I'm using the JVC DT-V1910, and can recommend it highly.
As for the CF24 vs CF25 vs 24p debate, I think more testing is needed with CF25, once you convert to NTSC and downconvert it to SD before one can make a final judgement on it. Let the rendering begin!
Terry Steyn
The DV Shop
Toronto, Canada
www.dvshop.ca
Re: Z1 First Impressions
Hi DV dude,
how does CinemaTone Type 2 look compare to DVX100a?
At least does it look more filmlike than FX-1?
