[FS: General] Z-Finder 3x | indiFOCUSpro | VidLED
DCERVENKA
The indiFocus Pro is the last item available for sale.
indiFOCUSpro - $200
The indiFOCUSpro is a height adjustable, closed gearbox, low noise, extremely low backlash, follow focus. This comes with a three sets of gears OR you can use the softwheel on *any* lens without having to worry about mounting the gears.
Includes:
1 x indiFOCUSpro
1 x Rail mount
3 x Gears
1 x Softwheel (allows you to use the indiFous without the gears on almost any lens!)
1 x Cine-Pitch Driver Gear
1 x set of tall height adjustment screws
1 x set of medium height adjustment screws
1 x set of small height adjustment screws
5 x allen keys
VidLED - "coolLED-40" ** SOLD! **
Super Bright LED light. Runs a loooong time of the Varizoom battery. Dimmable from 0 - 100% with *no* flicker (unlike the cheaper LED lights!)
1 x VidLED - #5203-CW40
1 x Varizoom Battery (with cable to connect to the light)
1 x Gel/filter Pack for VIDLED lights
!! Does *not* include charger or mount !! You can buy additional battery mounts directly from VIDLED: http://vidled.com/products.html OR use the varizoom charger (if you already own the monitor kit) OR at the links below:
DigiPower Power Pack DPS-9000S - > http://www.amazon.com/DigiPower-Powe...3482765&sr=8-2
Digipower DPS-9000 Universal Power Pack - (w/ additional device connections!) > http://www.amazon.com/Digipower-DPS-...3482900&sr=8-1
Z-Finder 3x - version 2 ** SOLD! **
Optical Viewfinders that allows DSLR cameras to have the correct form factor for video. It offers 3x focusable magnification,a 40mm diameter Zacuto optical designed lens, an eyecup preventing extraneous light leakage, a diopter and a field of view perfectly matched to 3” LCD screens.
Includes:
1 x Z-Finder 3x
1 x lanyard
** version 3 is out ($395) and offers some sort of de-fogging lens covers. I've never had any issue with this z-finder fogging up, but then again I live in California where it's always sunny and warm...
*** does NOT include the mounting frame because it's mounted to my Canon 7D. You can purchase a new one here for only $6.00: http://store.zacuto.com/Z-Finder-Mounting-Frame.html
