Hey guys,
This is my first time posting, but I've been lurking the boards here for a few months. The company I work for recently purchased 2 firestore drives, and after a few issues(dropouts, which is now fixed, and a bad battery) the drives seem to work perfect. However, I'm having a timecode issue!
When I press record, the HVX200's timecode does not move at all. It just stays put. The FS-100 is set to TC EXT because they said if you want to do pulldown it has to be set at that.
My question is, how do I get the timecode to start on the HVX200 when I press record? Is it the fact that I have no P2 cards the reason it is not starting (kind of defeats the purpose of getting the firestores huh)? Doing free run timecode doesn't work for us, and the search function on this forum didn't yeild any results for me. Any ideas? I set the fs-100 to Rec run, but I can't do pulldown apparently, and importing, there was a problem with timecode matching between clips. There were off by roughly 6 or so frames, and I couldn't get Final Cut to stitch them together.
I'll be calling Panasonic tomorrow, but I thought I'd run it by you guys first.
Thanks for your help,
Tim
Tim
