Xpress ProHD HDV editing
ChuckS
Currently I'm editing with the Adobe Video Collection in SD, I'm looking to upgrade for HDV. I can use Cineform AspectHD and edit in an intermediate format which requires considerably more bandwidth or purchase an NLE that edits HDV natively.
I read on the Avid website that version 5.2 edits HDV natively, is there anyone on this forum editing HDV natively and if so how do you monitor the HD during editing?
I don't personally have an HDV workflow, but according to the documentation you have the option of monitoring the HDV footage through the Avid Mojo. Mojo will down-convert the HDV to SD footage for display on any production monitor.
I know it's not a personal testimony, but perhaps it will help nontheless.
Chris
There are just things you love to hate about Avid - the fact that I have to purchase a "mojo" video card that costs almost as much as a G5 so I can downconvert to SD :undecided
I am hoping that a work around for this is just keeping my HC1 connected through firewire and monitoring the analog output from it.
Would it really be that hard for Avid to work with nVidia on say an FX540 so there could be a real-time HD monitor output for under $300.
Mojo is far from a video card and it provides many more benefits than just down converting HD footage. You should read up about it. It's an amazing piece of hardware that is definitely worth the price.
Chris
Chris
Sure, if your editing SD/DV. I have a Canopus DVRex RTPro that gives me a lot of real-time performance in SD. But all of the reading I have done so far regarding Mojo says that it doesn't do HDV. It downconverts the HDV to SD so you can view it on a SD client monitor. Hradly think that's worth an additional $1600.
Mojo may have some limitations but it has some great advantages too. Worth the price. I spent $1000 on mine. You can get them well under $1600 if you're a savvy shopper. The I/O configurations, 1:1 & 4:2:2 abilities are great. The Mojo's real-time processing power takes the load off your CPU and allows for client monitoring/color-correction. Plus you can use it to monitor the output of Adobe After Effects.
The Portable Digital Nonlinear Accelerator. The revolutionary Avid Mojo is the portable, powerful Digital Nonlinear Accelerator that delivers the unprecedented power of true real-time effects, real-time DV input and output and professional analog-to-DV media conversion to Avid Xpress Pro and other software.
Avid Mojo provides a full complement of real-time DV and analog input and output ports all wrapped in a rugged anodized aluminum case. Connected via a single FireWire cable to qualified Mac or PC systems, it is the first and only real-time video solution for notebook computers. Compact enough to take on location yet powerful enough to serve as the core of a video-editing suite, Avid Mojo connects to any qualified Mac or PC system via a single FireWire cable and scales from DV25 to uncompressed SD video.
The power of Avid Mojo, when used with Avid Xpress Pro Software, is much more then a DV/IO converter. Adding Avid Mojo to Avid Xpress Pro software enables the capture, editing, and playback of a single stream of 1:1 (uncompressed) standard definition video and the ability to mix & render uncompressed titles and graphics over DV media for the best looking video and effects possible at breakthrough price points.
Avid Mojo provides a full complement of real-time DV, S-Video and Composite I/O ports, plus optional Component video I/O, all wrapped in a rugged anodized aluminum case. Connected via a single FireWire cable to qualified Mac or PC systems, it is the first and only real-time video solution for notebook computers. Avid Xpress Pro has a scalable real-time architecture which not only provides real-time software preview but when used with Avid Mojo DNA delivers true real-time video out to tape over a FireWire connection. Avid Xpress Pro with Avid Mojo is scalable from DV to uncompressed SD so editors can be more creative and get more work done in less time, all with legendary Avid quality.
Includes Avid Mojo DNA, Avid Mojo DNA stand, AC adapter and power cable, FireWire cable, "Using the Avid Mojo DNA" CD-ROM, Installation poster. * True Real-Time Video - Real-time DV output to tape with real-time 2D and 3D DVE (Digital Video Effects). - The portable Avid DNA for true, mobile real-time performance. - Real-time Analog-to-DV and DV-to-Analog conversion. - Real-time uncompressed graphics and titles via analog output port. - Real-time video monitoring * Advanced Input/Output - Single-cable FireWire connection to laptop and desktop computers (no PCI slot required). - S-Video, Composite, and DV input and output - Frame-accurate output to tape - Multi-channel audio punch-in with low-latency monitoring - Uncompressed SD video over FireWire * Highest Quality Media - Built to scale from DV to uncompressed SD - Genlock synchronization to black burst both analog and digital ports - 20-bit analog audio input and output - 24-bit audio file compatible with Digidesign Pro Tools - Support for both NTSC and PAL * Avid Mojo supports component input and output via a professional I/O cable option. Two cables are provided - one for input and one for output. Customers who require component video I/O simply connect the cables into Avid Mojos S-Video and composite input and output connectors. The cables each terminate with three BNC connectors for connection to a professional deck. This solution takes advantage of Avid Mojo's innovative design and portability while providing high quality component video I/O (4:2:2) for customers who require these connections - especially those that wish to take full advantage of Avid Mojo s 1:1 media capture and playback support.
