XDCam Transfer issue: Some Help Needed
Kholi
Section Moderator
Currently running:
10.5.5
Quicktime 7.5.5
XDCam EX Transfer Software 2.7.1
Have installed the XDCAm EX Driver
The Problem: I can only see ONE clip in the XDCAM EX browser, the rest have no image available and I can't import.
What's going on here?
Did you recorded the event with out stopping?
Did you try playing the clip to see if the entire video is there?
There are about twenty separate clips, actually. And, only one of them shows up properly. THe quality was never changed or anything like that.
I'm assumin' it's a software issue.
Kholi, very strange. I have not seen this.
You might want to try the older browser 1.1? if it's still around.
Do the others show as a black clip?
Quick XD cam transfer question. Is it possible to transfer to an external hard drive and check the footage on a Mac Book pro without the use of FCP v6? With P2 you can simply drag and drop to a hard drive and then check for the footage with the P2 Browser software. Is there a similar method for XD transfers?
thanks
I don't know anything about XDCAM transfer, but you can definetly do that with Clip Browser.
