John Brawley
Hi John.
Are you using a macpro or macbook pro for grading and editing the CininemaDNG files?
Cheers
Adam
I'm working off a macbook pro 17" i7.
jb
Hi John.
Cheers
Adam
Since this is a workflow topic, I'm putting out my curiosity...
With RED, I've always wanted to shoot to the SSDs, and have an external HD-SDI recording simultaneously for immediate dailies/proxies to cut with.
The question is if the Magic Cam's 3G-SDI link sends over ALL of the metadata and what recorder can read and store it. In this case, the recorder's ProRes or DNxHD proxies have whatever LUT's applied already on them, you take those and cut with them, then XML back to Resolve to finish, back out for a 2.5K master.
Dump the Proxies after the project is done. The trade-off's buying, attaching, and powering one more piece to the puzzle but not having to wait to render out material to edit.
Just tried to load some 12bit CineDNX files into Premiere - doesn´t work. There is an importer plugin from Adobe, but it also acts up.
After Effects eats the CineDNX single frames and the MFX version just fine.
If you load the single frames (click on the first frame only) a window that looks like the Photoshop RAW importer pops up and you can do 1stLight corrections.
You could now create proxie files from this or just import the AE project in Premiere.
Still a bit slow and awkward, but technically it works.
I hope Premiere CS6 can handle the files natively though, so we can skip the AE processing.
On the other hand, I expect 80% of the BMCC users gonna record in ProRes anyway, so you just can drop the material on the timeline and start editing.
Frank
I forsee raw almost unworkable for a lot of people- in practice.
which is better. 1, 2, or 3
1 Shoot directly in prores or DNXHD
or
2 SHOOT in RAW / then immediately transfer to favorite editing codec / then destroy raw files to release drive space.
3. Same as 2, but possible cineform as the new master.
any thoughts?
thanks
It'll all depend on what you're doing. I'm so used to shooting RED RAW that it's probably always gonna be 2, but it's good to have the option of 1+REC709 for really quick stuff.
thanks, my basic needs would be
a. general footage for features/ web.
b. GREEN screen { Ive never shot 4 4 4 green screen before, so I dont know if the improvement will justify shooting raw , transferring best takes to edit format { destroy raw footage} { or just green screening with 4 -2-2 , as now }
c. Matching to 3d animation / vfx
No reason not to use CinemaDNG unless you just don't like the workflow.
not sure what you mean by real deal keying. i guess you mean finally the real stuff!Resolve > DPX = Real deal Keying
Could also use ProRes4444 out of Resolve. .
Kholi and John ...thanks - giving me a beginners primer - personally I don't see any reason to buy this camera unless your'e going for the 13 stops by shooting raw - and since john is using a 17 macpro...I think the macmini server edition might be the cheapest entry point for macs - thanks again and look forward to the faq
Although John and I both already posted this in response to your first post... I can't figure out why you're trying to work directly with RAW for an edit...
jb
