JaredSMark
I have a couple C-stands and the adapters to mount a 40" slider on them. The slider is good, but I find that the C-stands are a bit wobbly. Sandbagging the bases of the stands won't help because I don't think that's the issue. I think what's causing it is the longevity between where the main pole connects from the base to the top of it. Since it's a long area there you'll get wobbliness no matter what. I've secured and tightened every part of the stands and have taken the risers down all the way but the problem persists. If these were really 'short' stands I don't think there would be a problem.
Do I have any options for stabilizing the stands further, or should I just call it quits with them and find a better solution? I'm leaning toward not using the stands at all right now but wanted to check with you guys.
