Can anyone tell if there is another system out there that will let me use my dvx wirelessly? I would like to be able to move around while folks can see whats going on, mobile cctv if you will, is the camwave from idxtech the only game in town?
If you want a short range, monitroring only signal, then a cheap 2.4GHz unit will do the trick. If you want a prodcution level signal, then it will cost you MUCH much more.
The Camwave is a good middle of the line unit: The picture quality is good, and it's very robust, however there is a slight lag in the transmission, so it coudl cause problems with lipsync/multicamera production.
I have used "ShotWatcher" with great success. Vortex Media is the vendor/manufacturer. I've heard they no longer make it. But, if you can find one it's a good product.
