You might beable to find a box that turns your video into cat5 networking cable. i know its out there, do a search on the net..
I don't have any suggestions for a wireless setup, but I know they can get pretty expensive and unreliable.
I think it might be cheaper to hire someone to monitor it for you.![]()
wht do you need to monitor? Framing?
If so there are a number of security application transmitter/receivers that will take a composite signal and send it and recieve it well enough to allow you to judge your composition but certainly not quality of image. If that is what you are looking for let me know or do an ebay search. If it is just a couple of hundred feetgo with the hard wire kits for very little like the Cat5 mentioned above.
Actually Radio Shack sells one. It is AC powered but through a 12VDC transformer. You can make a small gell cell battery run it with a little electrical know how. The range and quality isn't great but it works.
