timapter
not always. sometimes you can, sometimes you cant, sometimes you wouldnt want to anyways.
usually the problem is just that you arent on the same set of frequencies as the other system, but even if you're lucky, you'll often have problems to do with companding which is a complicated thing to try and explain.
so, sort answer: occasionally yes, most times no.
