Have a client who would like to have a live event broadcast onto a large screen for viewing. Anyone have any recommendations? I really dont want to have any wires to drag around. Also a servo unit to use. Would need a long extension to use with crane.
Yes, but on a much much grander scale. - That paticular unit is for MONITORING only. (Says it right on the page title)
I'v done a lot of screen (and other live work) in the lower budget area, and I've also done a notable anoutn of work with the cheaper radio links. The rule of thumb is that any link that costs less than a thousand dollars will be uselss - it WILL give you drop outs in most all situations, and this doesn't mean that every expensive one will work perfectly either.
In the UK a day rental of a suitable device will cost a couple of hundred pounds a day.
Remeber the Triangle of Turth: "Good-Cheap-Quick, choose 2."
It's Live, so that's "Quick" chosen. And you can't get a Good Cheap radio link.
So if you need a good stable picture (generally the case for a screen gig), and you are a budget. (Read: Using a MiniDV camera) then it really is worth it to just pull the cable, it will pay off in the end, in not only money and quality, but also it will be less work!
