wireless monitoring with HPX170???
On upcoming gig where they will be using their HPX170. Im not that familiar with this camera, having it used only a few times, still anyone can recommend best solution to wireless monitor the action (i'll need it so the director can give cues for he cast)?
Haven't used it on the HPX, but works great on every Arri cameras (with standard def IVS) I have used. That said, remember Canatrans give a SD signal, so make sure you're setting the HDI out (the BNC plug located at the rear of the camera) to standard def... , assuming you are recording on P2 cards. Don't forget you will need a receiver too, and the quality of the image will depends of the interferences at the location you are at. Plus, the Canatrans I have used powered from 3 pins 24v to the camera. The HPX does NOT have power out ports, so make sure you can power your Canatrans unit externally...
