Wireless Microphone System Are these good?
you can do better.
The first brand I've never heard of, the Azdens are ok, but those prices are prety high.
- Mikko
I want to use two mics at once. Can anyone recomend a good Wireless mic set. I've been reading about these for hours and still have no clue as to whats the best.
I have the Azden WR22 wireless lav set. It cost around $250-300 if I remember correctly. Not great, but pretty reliable.
Well you either need a dual channel setup or 2 receivers, I would say the AZDEN 200 will suit your needs perfectly, it's basically 2 receivers in one unit and will have 2 XLR outputs. I thought about purchasing it myself for a while until I realized I would not need both mics to work simultaneously.
I would suggest you go to your local dealer if you have one and ask them for a unit to demo or rent system. I would also suggest looking into spending the same money you would spend for a new low cost system and spending it on a good quality hi-end system. You can check out Trew Audio dot com as one source for prices and what is out there. This is a pro film and tv audio biz that has a good used sectionof high quality gear. So yu will find the Lectros and Microns as well as the higher end Sennheisers (ew500 series) sand others.
But if it were me I would also slap a mini-disk recorder and a nice countryman on the rider as back-up . I am sure many here will tell
you the same thing....nothing beats a wire!
I use Micron and Sennheiser wirless systems.
