FS7: Wireless Audio Mount Solution
digitalinnovations
Does anyone have a mount solution for their wireless audio receivers? I have a couple Lectro systems and I'd like to find a way to mount / secure them to the camera itself instead of running cables or whatever - it can be a bit of a pain if you're trying to move quickly, on a monopod or stesdicam. Love to hear your solutions.
Unless you go with the Sony (only 1 w/l mic) hotshoe mount. There is no off the shelf solution I know of. That is not to say it can't be done custom, but it would cost a bit.
As far as mounting the RX's there are many solutions. I make a very compact shoulder and 15mm Rail system for the FS7. You don't have to use the Rails at all, I make a small bracket in the back that can hold 2 wireless mics and many other items like Brick battery plates or monitors.
If you like you can contact me directly and we can discuss options. I do a lot of custom kits.
Use the supplied bracket that came with your camera? It's meant for other wireless purposes, but may take your receivers quite happily. Check for an L-shaped bracket inside your box.
I use the same odd little bracket Ben mentioned and put sticky velcro on it, then put the opposite on G3's. Easy solution. Its small though and while good for G3 or mini lectro's might not handle the bid ones.
Thank you all! I'm definitely going to try the supplied bracket solution first. I'm running the 400 series Lectro so I may need to reinforce with a zip tie or something. Thanks again!
